TT suspension questions
Old Dec 22, 2004 | 03:32 PM
Vesaijan's Avatar
Default TT suspension questions
Hi all, I'm new to the forum. I need info on the S-line suspension from stratmosphere.com...Worth it or not? Will I need an alignment kit?
Also, after reading their site, I've come to the conclusion that the rear OE shocks are valved tight enough to handle a stiffer spring, while the fronts are not...if as follows, would it therefore be reasonable to say that I can run a set of H&R's, Koni fronts, and maintain the OE rear shocks without too much trouble?
Any comments will be welcome.
Thanks,
RL
Old Jan 31, 2005 | 04:05 AM
auditt1.8l's Avatar
Default RE: TT suspension questions
ORIGINAL: Vesaijan
Thanks,
RL
Hello, I'm no expert but my humble opinion is for the about the same $$ you could buy yourself a set of true coil overs and probable much happier with the end results.
ObnoxiousDrunk
Feb 28, 2009 08:38 PM
johnnythefox
Feb 18, 2009 09:54 PM
getch74
Feb 12, 2007 04:07 PM
fobyulous
Jan 29, 2007 01:47 AM
rowingdude
Jun 27, 2005 10:05 PM
