TTweakers
ORIGINAL: ouTTie914
Yeah I'm still going through all 82 pages trying learn myself something.
You don't have vag-com clipse? For some reason I thunked you did.
unfortunately i dont. i haven't had time to rebuild the laptop (busted hdd, fried mobo and proc. from overclocking). whenever i get my lazy *** up and rebuild it, ill pick up a cable and shtuff
Yeah, I went through the guide yesterday and was playin' with stuff. The Output Tests for Instrumentation is cool just to go through. I set the instrument panel to backlight the numbers whenever the car is on.
This guide ought to be a sticky or added to the FAQ.
Everything in there is explained very well. Definitely a site that's worthy of a bookmark!
Clipse you know the bentley manual now works with vista right?
That was my main problem with the repair manual anyway. Considering my old laptop won't work unless it's plugged in.
Jetta your cluster doesn't do that stock... weird. Must be something they changed with the newer models.
...brain fart
...brain fart
ORIGINAL: ouTTie914
ORIGINAL: ouTTie914
Clipse you know vag-com now works with vista right?
That was my main problem with vag-com anyway. Considering my old laptop won't work unless it's plugged in.
hmm.. im curious why it wouldn't? also why USB is causing more failures than serial cables. even with USB 2.0, im pretty sure it won't cause much data loss. wonder if there's a vag-com fire wire cable...
I'm pretty sure the gauges and needles are lit when the headlights are off.
All I know for sure is when the headlights are on there's a little green light to let me know.
The bentley manual just wouldn't open on vista.
The instructions to make it work were to change one of the setting so it would run as administrator er sumptin like that.
For vag-com I read that thread on vortex about the one usb cable not working properly.
Other than that one type of UBS cable I Haven't heard anything else about it.
Edit: Ugh... had a brain fart!
