Tune-up....
Old Aug 14, 2008 | 03:56 PM
01TT225Q's Avatar
Default Tune-up....
I know everyone has their preferences....What is the hot setup for spark plugs on this vehicle? There a good common plug most of us put in it?
Old Aug 14, 2008 | 05:53 PM
achTTung's Avatar
I've stuck with the iridium plugs to date, ran NGK's at first, and now trying out Denso plugs. At nearly $12 a plug, Im gonna say, probably not really worth it. Main thing is maintaining a proper gap, and replacing them when they wear. Otherwise, do you REALLY expect to see a noticeable change in performance from plug to plug?
Old Aug 14, 2008 | 07:11 PM
cincyTT's Avatar
I'm make believe
NGK BKR6 or 7's depending on chipped or not. Have been running them for almost as long as i have ran the car. Great plug for $2 each and changed every other oil change
Old Aug 14, 2008 | 07:45 PM
01TT225Q's Avatar
Thanks Cincy, exactly what I was looking for.
Old Aug 14, 2008 | 08:46 PM
beachchair's Avatar
Originally Posted by achTTung
I've stuck with the iridium plugs to date, ran NGK's at first, and now trying out Denso plugs. Nearly $12 a plug
Check out Iridium Prices at Summit. A little over $7. Even with shipping you'll come out way ahead.
Old Aug 15, 2008 | 08:29 PM
ooTToo's Avatar
ive had my TT a little while and wanted to know if I should change my spark plugs.. it only has 26k miles but it is a 2001.. with the age would it be best to go ahead and change them or when should i wait until ?
Old Aug 15, 2008 | 08:32 PM
cincyTT's Avatar
I'm make believe
If you are not sure about plugs, always change them. They only cost ~$8 for some NGK's so its not like its a major expense.
Old Aug 15, 2008 | 08:43 PM
ooTToo's Avatar
*edit*
judeisnotobscure
Sep 14, 2015 12:28 AM
rsonistxl
Oct 19, 2009 07:05 PM
phlash
Jul 26, 2007 04:26 PM
225tt
Nov 3, 2006 12:51 PM
Turbonium
Jul 19, 2006 01:17 PM
