Turbo gasket Leak???
Old Mar 13, 2008 | 06:55 PM
Thepianist15's Avatar
Default Turbo gasket Leak???
I just pulled out my 01 TT quattro for the beautiful weather in wisconsin and after a short drive without engaging the turbo too much, I noticed that there was a little smoke coming out if a hose. I'm not sure if its the turbo or not. The smoke isn't really in large amounts, but is definitely noticeable with smell and you can see it with close observation.
Its coming out of the heat shielding around on the hoses near the back topside of the engine. I"m assuming its one of the hoses leading into theturbo.
My first guess was a turbo gasket leak but the turbo has not lost any psi. I'm now thinking its a valve cover gasket leak.
Any ideas?
Old Mar 13, 2008 | 06:56 PM
Default RE: Turbo gasket Leak???
There is a picture of where the smoke is coming out
Old Mar 13, 2008 | 07:08 PM
cincyTT's Avatar
I'm make believe
If you drive it more and it continues, then i would start to worry. Could of been oil that pooled in the intake when it sat and the heat from the turbo just burned it off.
Old Mar 13, 2008 | 08:00 PM
Senater_Cache's Avatar
check if there are any wires / hoses that have come loose and "fell" or rather drooped down touching the manifold or something.
They may be burning up or melting.
I had the wire-loom around my boost gauge hose touching my TIP/Heatshield and it melted.
Old Mar 13, 2008 | 08:55 PM
That a good point. It doesn't smell like an oil burning, its something synthetic.
Thanks
Octane567
Aug 8, 2014 10:28 AM
A6Isaac
Mar 27, 2013 09:19 PM
sabresfan
Dec 2, 2012 07:32 PM
Quattro_1.8t
Nov 18, 2008 01:16 AM
lewishw
Nov 26, 2005 07:53 PM
