turn signal stops after a few blinks
Old Dec 19, 2005 | 09:44 PM
TTsteve's Avatar
Default turn signal stops after a few blinks
has anyone had their turn signals stop after a few blinks? Mine blinks for about 4 or 5 times and then stops.
Old Dec 20, 2005 | 09:35 PM
AudiTech04's Avatar
Default RE: turn signal stops after a few blinks
Its a hazard switch or a turn signal switch
the first one is easier to do
Old Dec 21, 2005 | 04:22 PM
RussTT's Avatar
I have a similar issue with mine where the turn signal studders for a sec and then goes normal then a few seconds later it will go studder again. All my signal lights seem to work and they also studder when the signal does.
You think it could be the turn signal switch?
Old Dec 21, 2005 | 07:20 PM
TTsteve's Avatar
My signals did the same thing before too but now they just blink a couple of times and then stop. I guess I will find the flasher fuse and replace it and see if that does the trick. I just hope its not real expensive.
Old Dec 21, 2005 | 10:19 PM
AudiTech04's Avatar
Did either of you happen to read my post
Its the hazard switch
You know its the one above the radio with the triangle on it
That is you problem
Old Dec 28, 2005 | 07:38 PM
TTsteve's Avatar
where is the hazard switch located and do you know how much it will cost? Thanks.
Old Dec 28, 2005 | 08:23 PM
AudiTech04's Avatar
ORIGINAL: AudiTech04
That is you problem
Come on man did you read the post
Old Dec 29, 2005 | 01:34 PM
RussTT's Avatar
How could the switch itself cause the issue wouldent it be the relay connected to the switch??
Old Dec 29, 2005 | 05:35 PM
TTsteve's Avatar
Thaat sounds about right to me too RussTT, besides I have tried the hazards and they dont stop blinking after a few blinks so Im not sure if the hazards and the blinkers are on the same relay or not. Im just trying to find where the relays are located.
Old Dec 29, 2005 | 09:00 PM
AudiTech04's Avatar
Heres the deal
The switch is the relay, just replace it and tell me if it works
