Uni or Tapp
Old Mar 28, 2009 | 12:53 PM
rayveedub's Avatar
honestly i dont think you could do better regardless of your choice. obviously i will be going uni 1200cc on my tt whenever i get my crankshaft back . im hoping to make some good power. ive seen success on both platforms though. ive got alot of people uni bt software and pretty much never had a issue and the cars have stock like driveability.
Old Mar 28, 2009 | 03:27 PM
cincyTT's Avatar
I'm make believe
They only real diff is that uni can adjust timing based on octane and iats depending on if your engine is built or not. This makes a race file not needed. With the tapp file you will have to adjust timing yourself via unisettings which isnt a big deal. Still have to say that the nbo2 is the biggest deciding factor
Old Mar 28, 2009 | 09:02 PM
bvgoosedd's Avatar
so let me get this straight, If i go to the track and use race fuel. with uni i don't have to do anything. and with tapp i'd have to plug into the ecu and change some settings. Is that what you mean?
Old Mar 28, 2009 | 11:28 PM
cincyTT's Avatar
I'm make believe
Something like that. Tapp has a separate race file, but if you wmi or can advance timing, you will have to do that with vagcom. You should have a vag anyways and its still needed for both tunes to max out your setup
Old Mar 31, 2009 | 02:51 PM
bvgoosedd's Avatar
one more question came to mind. if i get the mafless file and i have a maf in there will it use it or will it just be pointless to have?
Old Mar 31, 2009 | 03:37 PM
Wintermute's Avatar
Pointless.
Old Apr 15, 2009 | 08:24 PM
bvgoosedd's Avatar
sorry to bring it up again. but is it true you can't go mafless if you got a nbo2? i have a 02 amu audi tt 225. some1 told me i have to go with a maf. or is it just that tapp doesn't have the file.
Old Apr 15, 2009 | 08:43 PM
  #18
cincyTT's Avatar
I'm make believe
No, and doing so would be suck *****. Cant set a target a/f with a narrband o2 since its not that accurate. Thats the reason why everyone is changing to wbo2 ecus
FASTER
Sep 7, 2012 09:05 AM
Pablo_Ottawa
May 18, 2010 06:17 PM
preyash
Dec 8, 2008 10:32 PM
Jaxspeeddemon@aol
May 23, 2008 07:52 PM
Pablo_Ottawa
Aug 23, 2007 12:32 AM
