Vac-clamp tool
Anybody have a source for a tool to release the one-time use clamps on the vacuum lines? I have about effing had it with using visegrips/channel locks/needle nose pliers, looking for an easy solution or whatever tool the dealer uses- TIA
If you're talking about removing the clamp on the right here V V V
My cutters are dull, I can get part way thru the clamp, and then I have to give it a twist. It usually breaks loose fairly easily from that.
desertsnake1991
Dec 11, 2012 07:00 PM
