Vac-clamp tool
Old Jun 6, 2008 | 10:23 PM
cmh's Avatar
cmh
Default Vac-clamp tool
Anybody have a source for a tool to release the one-time use clamps on the vacuum lines? I have about effing had it with using visegrips/channel locks/needle nose pliers, looking for an easy solution or whatever tool the dealer uses- TIA
Old Jun 6, 2008 | 10:30 PM
cincyTT's Avatar
I'm make believe
Default RE: Vac-clamp tool
either just pull it off with clamp attached or use a tiny flathead to lift the end
cincyTT's Avatar
I'm make believe
and then a larger one to pop it off. I can pull most of them off and then remove the clip when off. Text limit posting
Old Jun 6, 2008 | 10:42 PM
cmh's Avatar
cmh
yeah I can coax them off, I'm just looking for a crush and go solution to save time and reduce my frustration[:@]
Old Jun 7, 2008 | 10:55 AM
achTTung's Avatar
If you're talking about removing the clamp on the right here V V V
My cutters are dull, I can get part way thru the clamp, and then I have to give it a twist. It usually breaks loose fairly easily from that.
Old Oct 7, 2010 | 11:54 AM
CitizenKane's Avatar
What's that tool called? And where do you get it?
bshusted
Jul 31, 2013 08:46 PM
desertsnake1991
Dec 11, 2012 07:00 PM
arb
Aug 12, 2006 12:50 AM
rnbguy
May 20, 2006 08:37 AM
tip5
Feb 4, 2006 07:34 PM
