Vacuum hose leak after P1136 "Too Lean" code—How do I get to the hose?
Old May 3, 2016 | 10:02 PM
Woodsie3's Avatar
Exclamation Vacuum hose leak after P1136 "Too Lean" code—How do I get to the hose?
Hey all. Recently my 2001 TT (225hp) gave me a check engine light and a P1136 code ("Long term fuel trim add. Fuel B1 system too lean.")
I was way overdue in swapping out my air filter, so I did that and cleaned the MAF sensor, but I had read that most likely this error was because of a leaky vacuum hose. Sure enough, I found the problem. It was sucking air pretty hard, but the problem is, it's wrapped in some kind of heat protection that's riveted together.
What is this part? How do I replace it without destroying the heat wrap?
Thanks, all!
Attached Thumbnails -20160503_183645.jpg   -20160503_183653.jpg   -20160503_183700.jpg   -20160503_183706.jpg
