Vag-com codes
Old Dec 5, 2007 | 08:43 PM
meanse's Avatar
Default Vag-com codes
I had an 8 year old MAF, so i replaced it... and after the replace i still have these codes
P1116
P1128
P0134
So, i think i have a leak somewhere and a dead o2 sensor? Any other ideas?
Old Dec 6, 2007 | 05:31 PM
meanse's Avatar
Default RE: Vag-com codes
no1 with any input?
Old Dec 6, 2007 | 05:38 PM
ouTTie914's Avatar
Nobody has any input because the answers can be found in the FAQ.
Bookmark this site!
17524 P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
16518 P0134 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
I'd start with checking the connection to your pre-cat 02 sensor... But that's just me. [8D]
Old Dec 6, 2007 | 05:48 PM
meanse's Avatar
i always thought losing an O2 sensor would cause my car to run rich? and a leak in the air system to cause it to run lean because of the un-accounted for air?
Old Dec 6, 2007 | 08:52 PM
themysteryman83's Avatar
Check for loose connections on the O2 sensor. If the problem doesn't go away, check for vacuum leaks. It usually has to be a fairly big one to throw a code.
Old Dec 6, 2007 | 08:56 PM
diehlryan's Avatar
are you clearing the codes and then running codes again after a driving cycle?
Old Dec 8, 2007 | 04:38 AM
meanse's Avatar
yeah i have cleared the codes and ran many cycles, the car seems very sluggish, so thats why i was thinking vacuum leak.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
