Is waste gate normally open
Old Dec 11, 2010 | 12:37 AM
phatboyfromla's Avatar
Default Is waste gate normally open
Is the wastegate normally open then it's closed by the N75 to allow boost? 2001 Quattro 225 AMU Type
Old Dec 11, 2010 | 12:05 PM
cincyTT's Avatar
I'm make believe
If its in your hand, it should be closed. The wastegate is open when in vacuum and then closes when you go wot and then opens again when the psi setting is reached (well, creeps open before that) to keep it there
Old Dec 11, 2010 | 12:54 PM
Thanks for the reply. Guess I'll do another leak test. Don't think my N75 is reading correct resistance either. My meter has X10 ohm setting and when I test across the N75 is goes to 1 which I'm assuming would be 10ohms? Thanks again.
browny355
May 27, 2011 10:04 AM
Pazza
Jun 5, 2009 02:50 PM
theguy1084
Jun 26, 2007 11:12 PM
beast a4
May 4, 2007 09:43 PM
True_Pinoy
Aug 3, 2006 05:07 AM
