weird noise ... someone help
Old Sep 6, 2008 | 01:40 PM
silverttq's Avatar
Banned
Default weird noise ... someone help
So yesterday the TT started making a very strange noise that I can't seem to figure out.
When I let off the gas, not only do I hear the DV (always have since i have an intake and intercooler), but then I hear what sounds almost like a SECOND DV on the passenger side of the vehicle (possibly coming from the wheel well?). It sounds almost like a snake hissing, and it even does it when I'm under low boost and just backing out of the driveway... and then sometimes when I'm just in fifth gear cruising around. I was thinking it could be one of the intercooler pipes coming lose, but I didn't see much. Sounds like a boost leak to me, but I have no clue where it could be at ... and it's only getting progressively louder.
What it truly sounds like, is there's a plastic bag stuck to the side of the car ... or something underneath the car that's scraping...but there isn't.
Any help would be much appreciated.
Old Sep 6, 2008 | 01:54 PM
theTTkid's Avatar
do you have a boost gauge to monitor boost?
Old Sep 6, 2008 | 02:50 PM
achTTung's Avatar
pressure tester (and soapy water) is your friend. this is as basic as it gets, anyone can build one. my friend has this, but with a valve stem from an old rim instead of a disconnect.
Old Sep 6, 2008 | 05:08 PM
silverttq's Avatar
Banned
Naw, no boost gauge yet unfortunately. That's on my list of things I NEED.
I spoke with an Audi Tech today that I happened to bump into at AutoZone, and he told me that i could bring it by his shop and he'll do a smoke test for $85 and find the problem..
I guess we'll see what happens. I'm thinking maybe it's just a crack in one of the rubber L pipes that I'm still using.
silverttq's Avatar
Banned
by the way, is it normal for the DV to make a shuddering sound? PSH PSH PSH ... versus PSSHHH ...
I'm thinking I might have a faulty DV as well.
And for further info, I have the P1136 code, system too lean, bank 1. These codes are driving me absolutely insane.
Anyways. Is it normal for the DV to make that type of sound?
Old Sep 6, 2008 | 05:21 PM
achTTung's Avatar
Maybe you missed this post...
https://www.audiforums.com/forum/sho...04&postcount=3
Smoke test = bunch of money
Self test = very little money
Crack a beer and light up a cigar while you look for bubbles if you want a smoke test. I'm about to go pressure test my car. You should do it EVERY time you have to loosen/remove a boost hose on your car.
Old Sep 6, 2008 | 05:22 PM
theTTkid's Avatar
if you want a boost gauge lemme know... id consider rippin out my awe gauge for a member...
(even though the liquid gague GB is over id consider one of those if i were you...)
Old Sep 6, 2008 | 07:48 PM
.clipse's Avatar
SoCal Crew Member
you had your chance... the same side inlet/outlet FMIC was recently sold =P
but it SURE does sound like a boost/vac leak to me. like said above, pressure test for sure since you dont have a boost gauge.
as for the DV noise, it'll sound more fluttery if you popped in an intake recently...
audia4man
Dec 27, 2012 08:14 AM
hearmespool
May 18, 2009 12:09 PM
brodieone
Nov 9, 2007 04:21 PM
cas4067
Aug 19, 2006 12:28 PM
jic534
Feb 18, 2006 01:11 PM
