What should i do to fix the baldness that occures on the inside edge of the tires??
Old Nov 3, 2006 | 02:57 AM
chancebuttars's Avatar
Default What should i do to fix the baldness that occures on the inside edge of the tires??
Okay so Igot new tires on my tt and a good 3 months later the inside edge of the tires are completly bald!!! The outside still looks fine.. I also did my 3000 mile tire rotation. So im thinking an alignment but I hear that its "normal" for the wheels to slightly bend inward. What would that be????
Old Nov 3, 2006 | 03:44 AM
eliTTe's Avatar
Default RE: What should i do to fix the baldness that occures on the inside edge of the tires??
Yes, it is normal for the rear wheels to lean in, but the tires should not be wearing out on the inside. I'm assuming your car is not lowered, take it in for a alignment and that should fix it.
Old Nov 3, 2006 | 12:54 PM
racer_x's Avatar
Is your car's suspension stock? Sounds like you've got too much negative camber... If you're not set up (suspension), go get an alignment and see if that does the trick!
Old Nov 3, 2006 | 01:16 PM
techbod's Avatar
Default RE: What should i do to fix the baldness that occurs on the inside edge of the tires??
not normal at all the tracking is out ( wheel alignment ) also could be worn suspension/control arms worn/over offset the list is quite long, what mods have you done to the wheels/suspension
bristimjet
Sep 23, 2013 03:26 PM
halfmoonclip
Jul 19, 2012 02:35 AM
roldanh9
Jan 28, 2011 08:38 PM
ag229487
Feb 21, 2007 10:13 PM
NCMurphy
Sep 24, 2006 07:13 PM
