Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Rear tires scalloping / warping on the inside HELP!
Old Jan 27, 2011 | 10:06 PM
roldanh9's Avatar
Default Rear tires scalloping / warping on the inside HELP!
Hello my 2003 A6 has been making a howling noise at speeds of 10-20 mph. I thought it was the wheel bearings but they are pretty tight. Today I decided to take off the rear tires and check them and when I run my hand across the inside rea tires, they feel uneven or wavy. The rest of the tire feels fine. What can I do about the tires? What causes the tires to do that? Anyone who can help I would appreciate!
Old Jan 28, 2011 | 06:05 PM
roldanh9's Avatar
***UPDATE***I put new tires on the back problem solved. Hope this helps any of you guys!!!
Old Jan 28, 2011 | 08:38 PM
aspen79's Avatar
The tires wear like that if the alignment is off. Cupping, chopping, etc is caused by the toe being out of whack. If the inside is chopped I'd suspect it's toed out. Please tell me you had a 4 wheel alignment done when the tires were put on! If the dealer or tire store didn't at least recommend it, shame on them. If not, get it done soon as you can. Your tires will thank you. They should also be rotated front to rear every 10,000 miles or so.
Oh yeah, there are some tires that are more suseptible to chopping. Cooper Zeon and Fusion brand are two that come to mind.
Tecnic91687
Nov 29, 2013 03:11 PM
bristimjet
Sep 23, 2013 03:26 PM
James94
Jul 14, 2011 03:40 PM
dec1184
Apr 10, 2008 10:01 PM
