Whats better DV or BOV?
Old Aug 5, 2008 | 12:07 PM
  #21
IndyTTom's Avatar
Thumbs up
Originally Posted by BigWilleh
like i stated im not using a BOV
and i will be installing the DV once i recieve it which will be in like 4 days and i will update on how it sounds. I heard some Forge DV on TTs and there is some noise to it but ya i like the BOV sound just not the "Loud" BOV though
Hey there BigWilleh,
Which Forge DV did you get? I used to use the 007p and it is a Great DV.
I recently switched to the Forge Splitter Valve which is still a DV but it does vent about 10% to athmosphere which gives you a nice shss sound and it is also fully adjustable without taking it apart everytime. So far I like the Splitter the BEST of all the other DV's I tried and I tried several.
If you want a little bit of sound/noise you should get an aftermarket intake to let your car breathe a little better. I have a BPi Flowstack along with an AEM dryflow filter and it works really well with the TT. Here are the links to those two items: http://www.bpinitiatives.com/stacks.php
you will need the 3inch to 3inch flow stack.
http://www.aempower.com/ViewProduct.aspx?ProductID=961
It's an excellent set up and less expensive than some of the custom intakes sold. You will get a lot more sound from your intake and you will also be able to hear the DV a lot more.
What are your current mods? One of the first mods you should get is a REVO tune or APR chip. That will transform your car into a totally different animal and your driving experience even more enjoyable. However, be careful since police are prone to pull you over a lot more because you can't get rid of that big smile on your face
Old Aug 5, 2008 | 01:29 PM
  #22
ooTToo's Avatar
<-- n00b 4 lyfe !
Old Aug 5, 2008 | 02:14 PM
  #23
rawburt's Avatar
Is this setup the same for 180 / 225? Is it recommended to run some sort of heatshield? And by any chance do you have any pics of the setup? Thanks man!
Old Aug 5, 2008 | 02:23 PM
  #24
cincyTT's Avatar
I'm make believe
the only difference between 180 and 225 will be you will need a 2.75-3" reducer coupler for the 180. A heat sheild isnt needed, but wont hurt if you really want to make one
Old Aug 5, 2008 | 02:31 PM
  #25
rawburt's Avatar
Thanks Cincy!
edit, I remember reading somewhere that there is a sensor of some sort that goes into the stock airbox... Do you re route that, let it hang... Or am I mistaken on what I read?
Old Aug 5, 2008 | 02:39 PM
  #26
cincyTT's Avatar
I'm make believe
you need a filter for the sai line thats attached to the airbox
Old Aug 5, 2008 | 03:32 PM
  #27
WishIWasRWD's Avatar
I went to the dollar store and bough a 3 pack of different sized kitchen drain filters.
Smallest one fit perfectly.
Not the best pics but...
Old Aug 5, 2008 | 06:10 PM
  #28
.clipse's Avatar
SoCal Crew Member
TECHNICALLY, i forced my trust intake (2.75" inlet) onto the 3" MAF of myzx's 225TT and works like a charm =)
Old Aug 5, 2008 | 06:17 PM
  #29
.clipse's Avatar
SoCal Crew Member
Originally Posted by cincyTT
There is more than enough info in the FAQs listed above that will more than answer any basic ? you will have. There is no reason to start a thread and then take info from 2 memebers that have both owned the car for as long as you and have 0 knowledge about the car. One of them is just a post ***** that bought a already done up car and the other needs to be spoon fed every last detail. Im sorry if any of you dont like my posts in this thread, but this crap is old and covered almost daily (thus the reason for an FAQ!!) so its readily available to anyone that is willing to take 2mins and read the info. Im sorry again if you didnt like my post but i think Chris above more than cleared that up for you also. Yes i can be an ***, but that is only set off by people that cant do things for themselves when its already given to them with a big bow on top
rofl. you always get em cinc
Old Aug 5, 2008 | 06:18 PM
  #30
rawburt's Avatar
My question is, whats prefered. Forge diverter 007 or Forge Splitter?
