what's the noise after I shut it off?
Old Mar 25, 2009 | 10:05 AM
jimfergie's Avatar
Default what's the noise after I shut it off?
just got an 02' tt coupe. The owner said they have an oil recirculating pump for the turbo that runs after the car's shut off. I'm familiar with other's having the water radiator fan run after shutting off. what's the little pump/ fan sound I hear after shutting it off? The first time home it ran for at least 5 or more minutes. I ran it for about a minute when it was cold and it ran for several minutes. Last night after driving it, I idled for 30 seconds, shut it off and it didn't run at all.
Old Mar 25, 2009 | 01:12 PM
TT225quattro's Avatar
I believe it may be the aux water pump, keeps the water circulating until car cools down a little
Old Mar 25, 2009 | 03:51 PM
ecko2702's Avatar
If you have the 225 you have an after run pump that circulates coolant through the turbo.
Old Mar 25, 2009 | 07:51 PM
DEjunkie's Avatar
Does this mean that letting the engine run after hard driving is not necessary? I have always been told to let the engine run to keep the oil moving. Maybe this is a different situation.
Thoughts?
Old Mar 25, 2009 | 10:08 PM
jimfergie's Avatar
thanks, I talked to a Audi, Mercedes, Porsche mechanic today he did mention a water recirculating pump that runs for a while.
Old Mar 25, 2009 | 10:33 PM
themysteryman83's Avatar
It's a coolant circulating pump and on the 225 you don't have to leave the car running like you do on the 180's. It will run anywhere from 2-10 minutes, and sometimes the fans will too.
Old Mar 26, 2009 | 12:55 AM
achTTung's Avatar
that doesn't mean its a good idea to shut the car off right after driving it hard. It only takes a couple of minutes of easy driving to let everything cool a bit before you shut it off. That goes for any car.
GustavoAyy
Jul 19, 2013 10:30 PM
VegasAudiGuy
Jan 18, 2011 12:08 PM
6605stang
Mar 7, 2009 03:11 AM
nickellis14
Feb 6, 2007 04:20 PM
eldrego
Jul 8, 2006 10:35 PM
