where to put my boost gauge?
Old Nov 9, 2007 | 03:01 PM
  #31
timbo108's Avatar
Default RE: where to put my boost gauge?
Anything mounted below the dash, within the footwell is tough on the shins of long-leggers like me.
If tapping into the fuse box, one of the top mounting bolts inside the cover is an earth ground. If I recall, the bolt head was tinted greenish. A continuity tester will tell you.
Old Nov 10, 2007 | 06:02 PM
  #32
Stunter4Hire's Avatar
if there is no blockage of the vent i think i might go with the centerleft vent gauge. Probs with autometer or faze...once its dont ill be sure to post some pictures and comment on it. Thank you guys so much for the great pics and advise. Who sells the mounting kit for the vent?
Old Nov 10, 2007 | 06:27 PM
  #33
cincyTT's Avatar
I'm make believe
you really dont need anything for it, the C band that comes with it should hold it in.
Old Nov 13, 2007 | 05:09 PM
  #34
TTMan's Avatar
posative wire goes to the 75x or somethnig like that on the bottom of the far left side and the ground just goes to the grounding spot with the 3 other grounds attached... i just installed my AWE one and its verry nice...
Old Nov 13, 2007 | 05:28 PM
  #35
scoTT la rock's Avatar
go AWE.
its a perfect match for the other gauges, it fits in the drivers vent like a glove, and you still get airflow around it.
Old Nov 13, 2007 | 05:46 PM
  #36
cincyTT's Avatar
I'm make believe
Not everyone want to spend $300 on a boost gauge.
Old Nov 13, 2007 | 05:48 PM
  #37
.clipse's Avatar
SoCal Crew Member
^ ya really. you can get like a 30 psi autometer for under $60
Old Nov 13, 2007 | 05:58 PM
  #38
cincyTT's Avatar
I'm make believe
I plan on needing something more like this
Old Nov 13, 2007 | 06:14 PM
  #39
jakej's Avatar
I'm gussing the gauge piller's for sale on ttstuff.com are a really bad fit?
Old Nov 13, 2007 | 06:15 PM
  #40
cincyTT's Avatar
I'm make believe
since they are for a supra i think. I wouldnt spend money on it
