why my tt won't start
Old Dec 4, 2006 | 12:33 AM
jonathan's Avatar
Default why my tt won't start
hello everyone, something really bad hapened today. i drove my car for about 15 minutes, it started good without prblems. honestly i wasn't going between 80 and 100 mph. when i got to the light, i put my car on neutral while i was lstening to music. when the light turn green, i notice my engine was off ( i didn't knew it was out as a result of the music) i tried to start the car i didn't so i had to call AAA.
is not the battery because i just changed and evething works fine
its has enought gas
is not chipped
when i try to start the engine it souds like it wants to start ,but there is something that is not giving the car enought has ( i think it has something to do with the injectors)
should i get starter spay o what should i do
please helppppppppppppppppp
thanks
Old Dec 4, 2006 | 12:57 AM
achTTung's Avatar
Default RE: why my tt won't start
honestly, take it to a shop. No offense, but the way you present yourself, it doesn't sound like you know what your doing under the hood.
Regardless of where it goes for work, you, or a shop is going to have to scan the car for fault codes before you try to do anything. Its the only way you'll really know what went wrong.
Old Dec 4, 2006 | 11:57 AM
BlackRaptor's Avatar
I also say take it to a shop.
Not worth the risk of more stuff going wrong.
Old Dec 5, 2006 | 01:46 AM
MauriSSio's Avatar
Member
fuel pump?
Old Dec 5, 2006 | 04:02 PM
MeanAudiA6's Avatar
timing belt is my first guess. have them remove the timing belt cover and see if there is play.
Old Dec 5, 2006 | 06:11 PM
XCLR8TT's Avatar
ORIGINAL: MeanAudiA6
That would be my first guess as well. Like has been discussed. When you hit 60K you better be serious about changing it. It can go without warning and the symptoms as described are exactly what will occur. Spend $700-$800 now in preventative maintenance or $5000-$7000 after it breaks.
Old Dec 5, 2006 | 11:18 PM
MeanAudiA6's Avatar
thats what my baby did to me, sounded like it wanted to turn over but no cigar. did you hear a slight ticking sound right before it happended? i thought it was the fuel pump too but i wasnt that lucky. you will be able to tell if you take the timing belt covers off and check for play.(and look for any missing teeth on the belt) also a compression test will tell you if it broke as well.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
