wierd problem - interior lights and alarm
So, my TT hasnt been giving me too much grief, and lately, my interior lights have been acting up (the dome lights). The dome light stopped coming on during cold days until it warmed up. The pass/driver map lights still came on when you pressed the button like normal, so I really didnt think it was a big deal and figured the bulb for the dome was failing.
Tonight, it got worse - none of them will come on. Doesn't matter if i lock the car, have it open or press the buttons - nothing.
Worse yet - my alarm is not engaging. It will not beep - nothing. My door LEDs blink real fast like 3 or 4 times and then don't blink again after that.
I pulled the 3 bulbs just in case the temp has something to do with it, I dont want my battery to drain if they do come on.
Any ideas? Is there a module up in the roof area above the (right rearview mirror)? A fuse? I know when I got the TT, it had some leaking issues from the roof antenna, but I fixed that leak the day it happened after the stealership changed the antenna.
