Yet another coilover question
Old Jan 19, 2008 | 07:16 PM
pitrman's Avatar
Default RE: Yet another coilover question
All I have to do is just agree with TTman, pss9s are probably the best you can put on.I have them set pretty low, but 'snot problem to get 'em a little bit higher within few minutes, you've got 9 adjustable heights, so you can adjust whatever you like. And with combination with the right sway bars, 18' + wheels, and sport tires, you can cut the corners like they did in Fast and Furious
Old Jan 19, 2008 | 08:00 PM
TTMan's Avatar
yea its amazing, 9 dampening settings and an infinate number of height adjustments from slamed to one inch below stock, anything looks great and handeling is absoloutley unparraleled.
Old Jan 20, 2008 | 06:30 PM
Ergokinetics's Avatar
Thanks again for all the help guys! I'll keep you posted on how the install goes. I figure this can be my winter project along with a TurboXS mbc that should be arriving any day now.
Old Jan 20, 2008 | 06:44 PM
diehlryan's Avatar
ORIGINAL: TTMan
no sweat man, they are truly amazing, good luck bro, if your installing them yourself make sure you disconnect the halfaxle and the control arms and take the whole breaking and bottom strut out of the car and pound on the bottom of the strut on the workbench... i didnt at first and i had to replace a cv boot that i tore, good luck, other then that its very straight forward, also set them at 8 in the begining, just to get the feel, and then go as agressive as you want, good luck pm me if you have any issues.
sounds like a lot more work than anywhere else I've seen..
Old Jan 22, 2008 | 10:15 AM
TTMan's Avatar
its just what i noticed in my install to make it easier thats all... the bottom of the strut was practically welded with rust to the hub/bottom strut area...
SouRce4
Jul 11, 2007 07:41 PM
germancarmaniac
Jan 26, 2007 06:32 PM
arb
Jan 13, 2007 02:47 PM
02tq
May 9, 2006 03:19 PM
BFlan2001
Aug 21, 2005 09:05 PM
