'00 headlights on a '98
Old Aug 10, 2005 | 07:30 PM
iano's Avatar
Default '00 headlights on a '98
i've been told the stock newer type one piece headlamp will replace the older two piece headlamp(and indicator). is this true? does it matter if i replace valeo with bosch or vice versa? what about the spot lamps in the headlamp unit itself?
Old Aug 10, 2005 | 07:35 PM
Jestnomen's Avatar
6th Gear
Default RE: '00 headlights on a '98
Yes you can replace the two piece headlights with the one piece ones, but it requires some modification. First the fenders on the older pre 99.9 cars have a lip that must be ground down. Second there will be some rewiring as they use different plugs.
Most people when they do this go for Ecode (european clearcorner lights).
http://www.audiworld.com/tech/ext17.shtml
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
