01 A4 Engine Swap to 2.7T
Old Feb 8, 2012 | 10:19 PM
kevinbednarek's Avatar
Default 01 A4 Engine Swap to 2.7T
So I have read a few threads on here bashing people who want to put an S4 engine in their A4. I have tried to sell my A4 to no avail because I'd like an S4. However, I have put too much money into my car to just start over on a new one.
So, my question is can mount an S4 engine on my 1.8T transmission? Apart from the ECU, wiring, hoses, etc, is there anything else I would need?
Old Feb 8, 2012 | 11:48 PM
twoeightquattro's Avatar
well the s4 has a six speed transmission, so why would you go with a five speed? if you're gonna go through all that trouble, just get a complete S4 drivetrain.
Old Feb 8, 2012 | 11:51 PM
The reason I asked is because I know a guy selling his engine that works perfectly for $1000. The tranny would be a pain to find for cheap. Would it mount to the 5 speed or would I NEED to swap to the 6 speed?
Old Feb 9, 2012 | 12:09 AM
well i'm almost certain that the 1.8t and the 2.8 have the same bellhousing mounts, just different gear ratios. and i'm almost certain that they used the same block for the 2.7t as the 2.8. The gear ratios would probably feel a little sketchy because your putting about double the power to the same gear ratios which are meant for the 1.8T.
wouldn't be surprised if the tranny couldn't take it.
Old Feb 9, 2012 | 11:03 AM
cincyTT's Avatar
I'm make believe
A gt28rs turbo kit will save you a massive headache, gas, and probably money. Plenty of power to get the car moving.
Old Feb 9, 2012 | 11:32 AM
Mike-2ptzero's Avatar
The 01A will bolt to the 2.7t block, there are plenty of 1.8t owners running 01E transmissions which bolted right onto the block.
I even know a S4 2.7t owner that swapped in a FWD 5 speed 1.8t transmission just for fun.
If you keep the 2.7t power stock then you will be ok. I had no problems with my 01A 5 speed while making 570whp with my built 2 liter setup.
Old Feb 9, 2012 | 12:06 PM
ImTheDevil's Avatar
Since when does anyone go into engine swap planning with the notion that it will or should be cheap? Occasionally it can be but if you're being real, you'll plan on considerable expense and having a big discretionary budget.
Old Feb 9, 2012 | 01:05 PM
01E can be a $2k-$3k added cost to the build. Exactly why I haven't put a 01E in my car yet.
Old Feb 9, 2012 | 01:26 PM
Nollywood's Avatar
The 2,7T would certainly bolt up to the 01A 5MT. An interesting project. If your car is DBW, the S4 2,7T harness will be plug and play.
You'll need a V6 front subframe, the I4 one will work, though it'll be pretty close around the upper oil pan. You'll also need the front bar and lock carrier off an S4, or a V6 at the very least.
If you'll need to change your instrument cluster coding, otherwise your tacho will not read right (it's coded for an I4).
So yes, it's very possible, how well the conversion's done will depend on how fussy you are, and how far you're willing to go.
Good luck, whatever you decide.
Old Feb 9, 2012 | 06:26 PM
vgo's Avatar
vgo
voila!
Audi s4 TIP to 6 Speed Transmission Conversion Swap Kit: Audis4parts.com
