01 Audi A4 1.8t Engine help
Hey guys, I know its a super late post, but I did check the spark in the car and there wasn't any. The spark plugs are new, so Im wondering if it is the coil packs or something else. Also there wasn't any fuel being pumped, I pulled out the injectors and nothing came out either so would it be a relay or is there somewhere I should check to find if there is running electricity? Thanks again!
Fuel pump relay is under the left side of the dash inside the car, you should hear it click on and then off 2 seconds later when you turn the key from off to run. Open the fuel filler cap and stick your ear by the opening. Have someone turn the key to run and see if you can hear the pump running.
When you replaced the timing belt did you pull the crank sensor out and replace it with the tool that holds the crank in place? If you did, did you put the crankshaft sensor back in, and is it all the way into the hole. If its not installed correctly and working you get no spark.
koenig22
Audi Q7
Mar 26, 2014 08:54 AM
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
winner007
Mar 4, 2007 01:50 PM
xxipsxx
Jan 1, 2007 05:30 PM
