02 sensors
Old Feb 16, 2010 | 04:07 PM
Andrew149's Avatar
Default 02 sensors
does anyone have a write up for the 2.8l? im gonna try to blow torch them and than blow them out with air
Old Feb 16, 2010 | 04:18 PM
Mr. Phil's Avatar
well Mr. hs graduate... i believe it's written "does anyone HAVE" not has... "and THEN blow torch them" not than
but on a serious note, what are you trying to do? just remove them or install them?
Old Feb 16, 2010 | 04:26 PM
Andrew149's Avatar
by blow torching them you will take the old carbon off the sensors since they are made to take such heat it will not damage the sensor as long as you only torch the tip of them it should create more accuracy... other people think dipping them in gas will work but the chemical is not strong enough to take off the dry carbon
Old Feb 16, 2010 | 04:41 PM
Mr. Phil's Avatar
well if u have an acidic base something tht might work... but if u gonna blow them make sure u do a low setting
Old Feb 16, 2010 | 05:02 PM
Andrew149's Avatar
acid would ruin the electronic part of them its really hard to tell what my results are gonna be.
Old Feb 16, 2010 | 05:16 PM
Mr. Phil's Avatar
if u had a spare that would be perfect... go to a pick a part or some random junkyard and ****** one out of there and test it to make sure it works then try it on that one
Old Feb 16, 2010 | 10:24 PM
2fast4u66's Avatar
GL, be neat if it works, But I bet you spend $60 on an universal one :P
Old Feb 17, 2010 | 10:55 AM
Andrew149's Avatar
where can you get them for 60?
trickyniki02
Mar 26, 2010 10:10 AM
khj677turbo
May 30, 2007 04:14 AM
klum00
Feb 2, 2007 06:30 PM
yamie
Dec 22, 2006 04:15 PM
1BADS4
Mar 31, 2006 04:23 AM
