Alright breather hose replaced today(PCV) and new spark plugs, also bumped the idle up to max its helps a little... However with the ac on feels like the engine is going to shake apart.. Attached is the vcds log, anyone have any ideas?
Bank Log
http://pastebin.com/78X6uWh9
VCDS-Lite Version: Release 1.2
Thursday, 16 April 2015, 17:48:19:47721
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: 078-907-551-ACK.LBL
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D01
Coding: 06201
Shop #: WSC 06435
VCID: 6CABFDDA0F93
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Coding: 0273004134
Shop #: BB 24302
VCID: 2823C1CADBEB
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06435
VCID: 2925C4CEC0E1
Address 15: Airbags Labels: 8D0-959-655-AI7.LBL
Controller: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06435
VCID: 40F3796A539B
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-919-xxx-17.LBL
Controller: 8D0 919 930 L
Component: B5-KOMBIINSTR. VDO D03
Coding: 00262
Shop #: WSC 00000
VCID: 370112B60655
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 N
Component: CV-Pump D05
Coding: 16140
Shop #: WSC 06435
VCID: 40F3796A539B
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
VCID: E0B319EA735B
1 Fault Found:
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 4B0 035 186
Component: Radio D01
Coding: 00117
Shop #: WSC 06435
VCID: DDCD201E4429
End --------------------------------------------------------------------------------------------------
Bank Log
Coding: 06201
Shop #: WSC 06435
VCID: 6CABFDDA0F93
4 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0302 - 35-00 - -
Coding: 0273004134
Shop #: BB 24302
VCID: 2823C1CADBEB
Coding: 04162
Shop #: WSC 06435
VCID: 2925C4CEC0E1
Coding: 00104
Shop #: WSC 06435
VCID: 40F3796A539B
1 Fault Found:
Coding: 00262
Shop #: WSC 00000
VCID: 370112B60655
Coding: 16140
Shop #: WSC 06435
VCID: 40F3796A539B
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 06435
VCID: E0B319EA735B
1 Fault Found:
35-00 - -
Coding: 00117
Shop #: WSC 06435
VCID: DDCD201E4429
