1.8t Engine Noise with Video Please Help
Okay so I have a 99 A4 1.8t manual trans that I just purchased. I have been researching this noise like crazy. The noise is loud when cold started and seems to disappear when warm/is very faint if you listen close. Noise goes away when rpms are raised. Car is still getting 29/30mpg on highway no CEL or oil light on currently. My suspicions: One being the CCT but not sure cause the CCT seems to be more of a light fast tick. Valve lifters and or Oil sludge problems maybe oil pump/strainer causing low oil pressure and lifters to make noise. I'm just hoping someone with experience can help pinpoint the actual cause. Any help appreciated! Video Below sorry its dark. Also car has 104,000 miles.
0813011904.3g2 - YouTube
Pull your coil packs and make sure the spark plugs are tight. I've seen this a lot with the bmw e36 and on bimmerforums. Always did the trick ! Also a good seafoaming in the oil and vacuum lines would help too ! Just change the oil after doing the seafoam
Edit* At least from this video is what it sounded like to me
