1.8T no spark at cylinder
Old May 14, 2009 | 08:37 PM
Sidewayzracer's Avatar
Default 1.8T no spark at cylinder
not sure the cylinder number but it is the second one back from the front of the car
i replaced the plugs and put in a new coil for that cyclinder but still same issue
i swapped it with one that works and i am still getting no spark im looking for clues be for a check the whole wiring harness for breaks
Old May 14, 2009 | 08:50 PM
Mike-2ptzero's Avatar
Cylinder number 2.
What year is your car? If you own a ndbw it is most likely the coil controller which you will find sitting on the stock air box.
When it goes bad it always seems to be #2 cylinder that misfires or no longer has spark.
Old May 14, 2009 | 08:56 PM
99 aeb engine though
hopefully just that and nor a broken wire sure as hell sounds like a better idea then running the wires lol
Old May 14, 2009 | 09:24 PM
is the coil controller the same as a ignition control module?
Old May 15, 2009 | 02:32 AM
ghost6303's Avatar
yes ignition control module. swap your coil packs around, if the misfire stays in cyl#2 then you have a bad ICM. if it moves to a new cylinder, then that is the bad coil pack.
Old May 15, 2009 | 02:47 AM
He said he did that on the main post. He still didnt get any spark after switching coils packs.
Old May 15, 2009 | 08:38 AM
kk next on my list but looks like ill need a ride to work for a few days
150$ the normall price on these?
or does some1 know a cheaper source
Old May 15, 2009 | 10:47 AM
Just make sure you get the better version since IIRC there are 2 versions on the market.
rshepler217
Nov 7, 2013 05:25 PM
sonsa4
Feb 13, 2012 12:09 PM
heywood08
Jul 9, 2011 01:34 AM
auditurbo381
Mar 22, 2008 06:01 PM
A4 the Quattro
Apr 27, 2006 04:35 PM
