1.8t overheating on highway only
Old Nov 25, 2012 | 05:28 PM
Fourx4lucas's Avatar
Default 1.8t overheating on highway only
I have a 99 a4 with the 1.8t
It's temp stay norm in town but as soon as I get on the highway the temp starts
Climbing and as soon as I slow down it cools down to norm
What could this be
Please help
Old Nov 25, 2012 | 07:05 PM
Bruce Leroy's Avatar
Could possibly be the water pump and/or check you radiator for leaks when its pressurized.
Old Nov 25, 2012 | 09:29 PM
If it was a water pump
How can I test it
Old Nov 25, 2012 | 09:58 PM
ajbenels's Avatar
Can you see any evidence of leakage, near timing belt cover, under engine, on the ground?
Another place to check is your hoses. A failing radiator hose will collapse when the pump is pumping hard. No leak, just collapse like sucking on straw too hard. Squeeze your radiator hoses, any lack of true firmness means it might collapse under high volumne. Replace the hoses first before going deep into any work. They should be cheapish.
Old Nov 26, 2012 | 12:31 AM
No evedence of leaks and I'm upper radator hose is
Kinda soft when cold like I can pinch it till both sides are touching with eas also my g12 level is at min
NickBroderick
Dec 9, 2009 03:08 AM
scoutii304
Jul 13, 2007 12:14 AM
auS4di
Jul 8, 2006 07:23 PM
Dudek12
Jun 8, 2005 05:40 PM
