1.8t Resonator Delete
Old Mar 11, 2010 | 02:11 PM
zakario's Avatar
http://www.ecodetuning.com/shop/cart..._detail&p=1338
this one.
^ and thanks dude! thats exactly the sound I was striving for.
aRIf's Avatar
here is mine with mid and end magnaflow
http://www.youtube.com/watch?v=4s69KLMwEzs
Old Mar 11, 2010 | 04:52 PM
kayakman13's Avatar
this one.
Are you sure its adjustable sound? The ratchet up top controls the amount of boost retention by way of adjustable valve spring rates. Stiffer springs = more retention.
Old Mar 11, 2010 | 07:57 PM
zakario's Avatar
yeah well the way the valves are setup, if you loosen it up enough but not too much to start loosing your boost you get what sounds like almost full BOV. Turn it like 6 clicks the other way and the spring is just tight enough to not let the BOV section open up and it becomes a quiet DV. there are like 64 clicks in total. if you care about tiny fractions of a psi of boost then you're right, but its essentially adjustable with the ratchet on top.
Old Mar 12, 2010 | 12:20 AM
kayakman13's Avatar
How many clicks are you running and are you stock or chipped? I'm running 15 clicks, and its alright. Stock boost.
Old Mar 12, 2010 | 08:30 PM
zakario's Avatar
A lot more than 15. I would guess almost 30 clicks but I'll check tomorrow. I peak at 23 psi and hold 18
burner5
Feb 24, 2020 12:27 PM
FishEye
Mar 30, 2012 03:23 AM
jmgrande
Jul 8, 2010 10:37 PM
A4 2000
Nov 18, 2009 06:44 PM
DÌEGØs AÜD!CTIØN
Nov 14, 2008 07:05 PM
