1.8T starter - clicks but not turning
Old May 29, 2013 | 06:48 AM
vtraudt's Avatar
Default 1.8T starter - clicks but not turning
Solenoid clicks, but starter not turning.
Took it out.
The solenoid clicks when 12V is applied (to connector "50", where grey push on connector goes).
The starter turns when 12V is applied to the shorter of the 2 large bolts, but NOT when applied to the long one where the 2 thick wires are bolted to.
Nothing connected to the pin left of "15A".
Is there an internal 'fuse' between the long/big and short/big nut?
What can be checked on the starter?
Since solenoid clicks and motor run: can it be fixed?
http://i853.photobucket.com/albums/a...ps0532416c.jpg
http://i853.photobucket.com/albums/a...ps2c0a1095.jpg
http://i853.photobucket.com/albums/a...ps68bd795d.jpg
http://i853.photobucket.com/albums/a...ps68279003.jpg
Old May 29, 2013 | 11:07 AM
CryptoStorm's Avatar
If you apply 12v to both the long lug and 50 it should engage the solenoid and turn the starter. If not it just means that the solenoid isn't passing voltage to the starter.. Your going to need a new starter solenoid
Old May 29, 2013 | 12:40 PM
vtraudt's Avatar
Figured. Couldn't find a solenoid locally (starter feel mechanically sound, no play, motor sounds good, solenoid kicks out strong). Picked up a used starter (even so I am 90% sure I have a starter from a 1.8T AEB laying around somehwere!).
Will install as is first; if not happy with the unit, can later still swap solenoid over later.
Internally, there must be relay to close battery contact to motor contact, which is likely bad.
AudiBrooklyn
Oct 14, 2012 06:27 PM
pullacowonaski
Mar 23, 2011 02:15 PM
johnstef
Nov 3, 2008 03:41 PM
Incubus
Apr 7, 2006 06:22 PM
