1 engine code, can't figure it out...
Old Apr 19, 2008 | 01:33 AM
Vegas34's Avatar
Default 1 engine code, can't figure it out...
It is...
17536 p1128 035 bank 1 mixture adaption (multi): system too lean
I've replaced the air filter and the MAF seems clean, reset the code...then in about 2 days it returns. Any suggestions? I can replace the MAF and O2 sensor, but hate to pay for all that if it's not needed. The car is an 01 A4 1.8T and it runs great. Thanks in advance...
Old Apr 19, 2008 | 02:08 AM
Vegas34's Avatar
Default RE: 1 engine code, can't figure it out...
oh, and i just did the timing belt kit, fluids, and plugs are next...but the code was on prior to all of this...
Old Apr 20, 2008 | 02:56 AM
Dallas09's Avatar
That can often be caused by a leaking vaccum line, u should pop the hood and listen for a hiss. When I had that problem i could hear it even when the engine is running. Otherwise u can search google for "boost leak detector" or something and there is instructions on how to presurize the system to listen for leaks. This would be the first thing to try since it is the cheapest out of all of the solutions and its fairly likely that thats the problem.
Old Apr 20, 2008 | 10:55 AM
CRAZYHAWK's Avatar
+1^
https://www.audiforums.com/m_562674/tm.htm
Old Apr 20, 2008 | 01:35 PM
RAZ301's Avatar
i had the same problem, i changed fule filter, maf, spark plugs, cables. so far the proble is fixed no more engine codes, but if it returns the next thing to check is an axhust leak. how is your exhaust?
calhoun_d
Apr 20, 2014 09:27 PM
rmr1499
Jan 5, 2013 10:09 AM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
A4TOTT
Mar 5, 2010 11:48 AM
