18" Avus S4 wheels on A4 B5?
Old Aug 1, 2013 | 12:12 PM
phatjames167's Avatar
Default 18" Avus S4 wheels on A4 B5?
Will the 18" Avus S4 wheel wirth 235/40/18 tires fit an 01 A4 with stock suspension or will I need spacers or anything extra?
Old Aug 1, 2013 | 03:37 PM
CCA4's Avatar
Should fit just fine.
Old Aug 1, 2013 | 04:36 PM
meloman's Avatar
It should fit, will probably be close.
I bought a set a couple years ago with 245's and they didnt fit.
Old Aug 1, 2013 | 09:26 PM
I was worried about the front but the rear has the smallest of gaps but this is what i have so far
Old Aug 7, 2013 | 03:34 PM
If i used H&R Race Springs with these wheels would it cause the tires to rub the control arms? It's a bit more aggressive than I would normally go but I found a unopened set on craigslist at a good price.
Audi B5 A4 Quattro 1.8T > Suspension > Springs > ES#658 Race Springs - Set - 29996-1
Old Aug 8, 2013 | 09:31 AM
CCA4's Avatar
I'm running Neuspeed Race springs on my car and its a tad bouncy. If you're already close to having rubbing issues I can only assume lowering the car more will make it worse. You could always pick up the springs and a set of spacers to have on hand just in case. If you don't need them you can just return them.
OG_35
May 25, 2010 12:11 AM
chupacobra
Dec 21, 2009 02:21 PM
krolls
Apr 30, 2009 10:28 PM
asanch15
Nov 22, 2008 06:16 AM
lambopilot
Oct 23, 2008 12:38 PM
