1996 a4 v6
Old Mar 27, 2011 | 12:33 AM
96audimtz's Avatar
Default 1996 a4 v6
was driving home after having oil trans fluis all diffs and brake fluid changed.....smoke was coming in to the car and wont start up again??? please help
Old Mar 27, 2011 | 02:37 AM
TheSphinxDzasta's Avatar
Default check fluids
Check fluids and see what is empty. No start sounds like engine oil. Did any lights come on the dash?
Old Mar 27, 2011 | 03:05 AM
Andrew149's Avatar
WHAT COMPLETE NOOB HERE^^^^ if he had no oil his engine would be blown WOW and how are engine lights are gonna come up with the engine isnt running???
Anyways what you will need to do is hook up a vagcom cable and run the car for code's see what pop up i had experience's with my 2.8 where it wouldnt start for 5mins come back car would start back up others on this forum say when they drive there 2.8 long distance its hard to start back up and BTW where did this smoke come from the exhaust?
Old Mar 27, 2011 | 06:45 AM
ImTheDevil's Avatar
Actually checking the fluid levels is a very good idea and is very conclusive most of the time. Vagcom isn't always the answer.
Old Mar 27, 2011 | 11:57 AM
96audimtz's Avatar
smoke was coming throught the ac vents........and no check enigine light turns on......when i turn the key to start nothing happenes no lights no sound nothing.......im new to these cars and just bought this.............i appretiate everyone aboves inoput....very thankfull..........going to check all fluid this morning and will post again.....please keep the helpful tips and advice comin....thank you all again!!!!!!
Old Mar 27, 2011 | 11:59 AM
96audimtz's Avatar
no lights come on that arent normally there on regular start up!!
Old Mar 27, 2011 | 09:49 PM
I may be a NOOB!! but I think that the computer throws the codes, not the engine itself. So unless he has complete PCM failure (Or a dead battery), you can still get codes. How would a VAGCOM get them? From the PCM or a running engine? Just trying to drink from the fountain of knowledge you provide.
Old Mar 27, 2011 | 09:53 PM
Check the battery, battery terminals, ignition relay, ignition switch, fuses
Old Mar 28, 2011 | 05:37 PM
Andrew149's Avatar
Dude you said did any lights come on the dash that means the engine has to be running for that to happen WOW
Old Mar 28, 2011 | 08:43 PM
^^^^^ ::::skurping sounds:::: AHHHHH!!! so refreshing.
Better get all I can before it dries up.
bmccloy
May 13, 2011 01:16 PM
bmccloy
May 13, 2011 01:09 PM
viviorunitia88
Sep 9, 2008 03:49 PM
III Wild Card
Apr 9, 2007 01:51 AM
