1996 Audi a4 2.8 12v v6 no spark Need Help
Old May 26, 2015 | 04:51 PM
jstrong16's Avatar
Default 1996 Audi a4 2.8 12v v6 no spark Need Help
As the description says I have no spark. I have fuel going to the rail. I have checked all fuses and relays. Changed coils, icm,ecu, crankshaft sensor, and cam shaft sensor. still have nothing at a loss. Any one have any ideas? Also I have checked timing and is all good. Also if any one is in the area that could help that would be great thanks.
Old May 26, 2015 | 06:51 PM
turbo510's Avatar
Have you pulled fault codes? You might have the clue just waiting to be read. From the sound of it, you seem to be just throwing parts at the car until you get to the faulty one. The connector for the ICM is a good place to start trouble-shooting, because if you see trigger signals from the ECU when cranking, you know the problem is between there and the coils. You'll also see if there is power for the coils, otherwise you can have firing signals, but no power for the ICM to distribute to the coils. You need a schematic of the ignition circuit to do this; if you don't have one, I can scan and provide it for your '96.
Old May 27, 2015 | 04:20 AM
jstrong16's Avatar
Yes I have codes p1340 and p1392.
Old Jul 24, 2015 | 08:37 PM
jstrong16's Avatar
bump......
Old Jul 27, 2015 | 07:26 PM
Mark C's Avatar
P1340 - Camshaft position (CMP) sensor 1/Bank 1/ crankshaft position (CKP) sensor - out of sequence
P1392 - Camshaft position (CMP) sensor 2/ Bank 2 - open circuit/short to positive
Old Jun 5, 2016 | 10:30 AM
Cap1334's Avatar
bump......
Hey man did you ever fix your problems I have recently ran into to the same situation and can't figure out why I have no spark
Old Jun 5, 2016 | 11:33 PM
ImTheDevil's Avatar
Cap1334, what codes do you have? Lots of things can cause this and his issues may not be the same as yours.
Old Jun 6, 2016 | 09:03 PM
jstrong16's Avatar
I have never got the problem fixed. The car is still seating in the driveway. Every One I have talked to can't figure it out. The codes I have were listed above. I have Changed everything. Unable to figure this out. Would love any help.
Old Jun 6, 2016 | 09:06 PM
jstrong16's Avatar
sitting
vtraudt
Nov 9, 2010 05:00 PM
Isramirez21
Apr 23, 2008 10:21 AM
Isramirez21
Apr 23, 2008 08:59 AM
Isramirez21
Apr 22, 2008 04:06 PM
m_hawk_1
May 14, 2007 03:45 AM
