1998 Audi a4 1.8T quattro wont move but runs. I think its clutch or transmission?
Old Apr 28, 2014 | 04:08 PM
not.so.hygh.lyfe.'s Avatar
Default 1998 Audi a4 1.8T quattro wont move but runs. I think its clutch or transmission?
HI,
I have a 1998 Audi a4 1.8 turbo Quattro and I don't know if my clutch or my transmission went out, I have a manual. Anyways, i was at a stop light and when it turned green i shifted into first gear as normal. I heard a weird snap/clank noise, and the car wouldn't move. So I turned the car off and than back on and still it would not move. i tried shifting without the clutch and the speedometer would jump to 30 if i put it in third. If anyone has the answer please help.
Thanks.
Old Apr 28, 2014 | 05:11 PM
redline380's Avatar
Legal Moderator
do any other gears work? try them all. You may have snapped only one shift fork inside the transmission, or you may have broke some linkage, or you may have clutch issues.
Press the clutch in and try 2-5 gears, and reverse. let the clutch out. if the car dies, you probably broke one shift fork. I'm a little rusty on my internal tranny knowledge, but I think if 1st and 2nd don't work, you broke that collar. 3-5 and reverse should work (meaning the car will die, except reverse it should move).
Old Apr 28, 2014 | 07:55 PM
I tried all the gears and the car wont move, when i shifted into 3rd gear without the clutch it would say i was going 30 on the speedometer without even touching the gas? i was really confused?!
Old Apr 28, 2014 | 10:21 PM
hartsoe1's Avatar
You may have broken a drive half shaft/CV/stripped a hub out. The Trans is spinning showing speed but the power goes to the spot of least resistance, the broken drive, so one of the drive half shafts could be spinning freely.
Old Apr 28, 2014 | 10:49 PM
okay, and I know the axels didn't break because I checked to see if they were spinning freely.
Old Apr 28, 2014 | 11:25 PM
redline380's Avatar
Legal Moderator
After a little thought, it might be your center diff. The speedo registering means the tranny and engine are linked. The next thing in succession is the diff. With that disabled, the car won't move.
Old Apr 29, 2014 | 09:44 AM
bshusted's Avatar
You checked to see if what was spinning freely? With all wheel drive, if you break the CV joint/shaft to just one wheel, the car will not move as all of the power is sent to the free spinning axle. My bet would be on a CV joint. Get under the car and try to move each shaft (up/down, in/out, left/right).
Old Apr 29, 2014 | 11:19 PM
okay I will check the cv shaft, and I will check the diff. tomorrow and I will get back to you guys. thanks for all the help.
Old Jan 31, 2015 | 08:01 PM
NickGL's Avatar
Have you found the problem i have simulare problem with mine as well
shan0223
Apr 22, 2015 07:38 PM
inspecta gadget
Jan 1, 2014 01:11 PM
alococo
Dec 18, 2012 11:50 AM
dcolect
May 14, 2011 04:31 PM
hatinyet
Oct 27, 2009 05:08 PM
