1999 A4 passenger rear wheel wobble in low gear.
Old Oct 7, 2012 | 06:03 PM
fueledbyA4's Avatar
Default 1999 A4 passenger rear wheel wobble in low gear.
I bought my 1999 A4 (1.8t, awd) just over a year ago, and the rear has bad creaking, only selectively it seems.
The problem is going with what i know from domestic cars is it is either bushings, springs or control arm issues. This still is not a problem.
The problem is with the passenger side rear wheel. It seems in low gear, the wheel wobbles dramatically. After shifting into 2nd, at 2000 rpms, it wobbles. If i shift in a high rpm i dont hear it. It is also effected greatly by tie pressure. If it drops below 38psi it is insanely noticeable.
Any one have a similar incident or any sort of solution to this? I replaced the bearings with no change just 4 months ago. This has been happening for about 6 months. It used to be only during turning but now even on a straight away.
Thanks in advance.
badinstincts
May 1, 2012 05:08 PM
djerik6
Sep 29, 2009 11:34 PM
smoovmusicdj
Feb 15, 2008 05:38 AM
Costner
Aug 10, 2007 02:55 PM
