2.6 INDUCTION KIT
Old Apr 24, 2008 | 05:28 PM
ImTheDevil's Avatar
Default RE: 2.6 INDUCTION KIT
Best way to get around that then, would be to use a drop-in panel filter for the airbox (I'd think SOMEONE makes one), and do the airbox mod listed in the DIY section of the forum to open up the area under the filter for fresh air intake. Other than that, you'd have to cut out the MAF from the airbox and then find a way to secure the cone filter onto it.
Old Apr 24, 2008 | 05:30 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: 44flan44
well its an 2.6 do a google search. on my air filter box the air flow meter is molded on to the box wers the 2.8 v6 its a pipe so u can connect an induction kit to it is ther a way i can get round it
only if they make a maf flange kit for the intake. This will let you pull the sensor from the housing and then install it in the intake.
Old Apr 24, 2008 | 05:38 PM
ImTheDevil's Avatar
Not sure if it'd work or not, but you could try and source a 2.8 MAF and use that along with the intake kit. I don't know if they're interchangeable, but you may find that a 2.8L MAF of the same model year as your 2.6 would work. Worth checking on anyhow.
Old Apr 24, 2008 | 05:56 PM
44flan44's Avatar
thanks, dose anyone know wer to look for a flange kit, or know if i can put the 2.8 maf on (not the electric bit the part it sits on)
Old Apr 24, 2008 | 06:57 PM
cincyTT's Avatar
I'm make believe
It will depend on the style of flange and diam of the tubing.
Think atpturbo.com sells the flange kits
Old Apr 24, 2008 | 09:51 PM
01AudiA4's Avatar
How slow is the 2.6? Not being mean just wondering. I feel bad knowing the speed of my 2.8
Old Apr 24, 2008 | 11:04 PM
chaos92287's Avatar
i dont know if your maf looks the same as mine but if it is here's a link for an adapter
http://www.genuinesaab.com/catalog/p...roducts_id=583
and then i also found this one that lists it fits all 96-04 vw/audi but it looks different. i would call them up and see whats up with that.
http://www.gt3turbo.com/Merchant/pro...411&page=1
Old Apr 25, 2008 | 01:19 PM
  #18
44flan44's Avatar
135a dident know thay done 2.8 or ad a got one but a only paid 1000 anyhow
Old Apr 27, 2008 | 12:31 PM
  #19
44flan44's Avatar
JUST WANT TO SAY THANKS TO ADVICE
GOT 78MM CROME PIPE AND CUT OUT AN OVEL OPENER AND PUT THE MAF SENSOR INTO IT AND IT SEAMS TO WORK
IF IT WASENT WORKING PROPERY WHAT WOULD THE SYMPTONS BE
THE K & N SOUND UNREALL A WAS SHOCKED
Old Apr 27, 2008 | 12:34 PM
  #20
cincyTT's Avatar
I'm make believe
Take 2
ORIGINAL: cincyTT
Posting in all caps = YELLING!!!
Please refrain from doing this.
