2.8 12v to 30v question
Old Dec 6, 2013 | 04:08 AM
Mhuntington's Avatar
Default 2.8 12v to 30v question
so my 97 a4 2.8 is the 12v. im considering swapping the heads out for a pair of 30v, if i can.
will the 30v heads bolt right up?
and will i have to flash my ECU or modify it with vag-com?
Old Dec 6, 2013 | 05:49 AM
M5S5's Avatar
Tech Certified
Why???
Old Dec 6, 2013 | 11:37 AM
turbo510's Avatar
The bolting up part might be the only thing that goes right. The ECU is totally different, the idle control, motor-driven throttle, e-gas pedal, exhaust manifolds, intake manifold, engine electrical harness, etc are all different. For 10% more power not worth it in my opinion.
Old Dec 6, 2013 | 04:15 PM
Mad Cow's Avatar
Not all 30v's are DBW, only those '00 and later. However the electronics are completely different, the 12v uses a Hitachi ECU and the 30v uses Bosch. The harnesses, sensors, and plugs are nothing alike, you'd have to basically swap over an entire parts car worth of stuff to make it work.
Old Dec 7, 2013 | 03:30 PM
well thats the point. my buddy wrapped his 98 2.8 30v around a pole last week. its getting totaled out, so im going to buy a bunch of parts off of him. he had a supercharger on his so hes buying another 2.8 30v to carry most of it over(SC, ecu, exhaust etc) either way ill easily be able to obtain anything i need for this swap. plus i can rebuild the heads if they need it without sacrificing ripping apart my daily driver yet
Old Dec 8, 2013 | 02:53 PM
Kamil`'s Avatar
To be completely honest, 10% power increase caused by the extra valves and diverter valve isn't enough to justify all that work but If you really wanna do it, go ahead. Post a nice DIY of how much fun you had.
Id rather spend money on a nice full stainless steel exhaust system, all the way from after the exhaust manifold to the muffler. Don't get me wrong, I've had crazy ideas before too, but I don't know if the swap makes sense.
Old Dec 8, 2013 | 03:21 PM
HBAudi's Avatar
Prior to beginning work, you may want to inquire from the local government agency responsible for smog inspections where the vehicle is to be operated if an engine not certified for that MY will be able to pass both a visual and emissions test. Usually modified vehicles are rejected without some type of exclusion issued by the government agency.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
