2.8 Auto pauses before first shift... should i be worried?
Old Mar 13, 2012 | 07:24 PM
brandontw's Avatar
Default 2.8 Auto pauses before first shift... should i be worried?
So, i go to start it up in the morning, she starts fine, shifts into D fine, and starts rolling no problem, but then it doesnt seem to want to go into second very readily...
It holds off for quite a while, and the RPMS go higher than normal, then finally shifts, and then it drives fine after that for the rest of the day, until i turn it off for a long time again.
I guess it has to do with it warming up? Is this kosher/normal?
Old Mar 13, 2012 | 07:43 PM
M5S5's Avatar
Tech Certified
It is normal for the transmission to hold shifts longer when the engine is cold. Not sure that you actually have a problem. Do you have a way of scanning the TCM?
Old Mar 14, 2012 | 12:23 AM
morpheous's Avatar
My 2001 A4 B5 1.8T shifts quickly,one gear after another,no pausing as long as your describing. I'd check your tranny fluid level.
I can scan my Transmission control module just fine,with my vag-com. if there is a issue with the tranny or TCM,the vag-com will pick it up.
Old Mar 14, 2012 | 12:36 AM
haggardtrish's Avatar
Mine had the same problem as you, brought it in, discovered there was a transmission fluid leak. Fixed the leak and had a fluid drain and fill, and its back to shifting as quickly and smoothly as it used to
Old Mar 14, 2012 | 12:21 PM
brandontw's Avatar
Well, sounds like i need to have a look at the tranny fluid levels...
As far as the vag-com, I got a cheap ebay usb-obdII cable, and the ross-tech free version software. Doesn't work worth a crap... so that is out i spose.
Old Mar 14, 2012 | 01:37 PM
redmond1501's Avatar
I've had the same issue for 4-5 months, now I'm getting a whining noise that sounds like a belt rubbing on a pulley.
I'm going to get the blauparts fluid, gasket and filter kit. My buddy just installed a lift so that should make things easier.
PeteMI
Dec 10, 2014 06:49 AM
inanitydefined
Oct 24, 2010 11:24 AM
a4r6
Jan 7, 2009 04:20 PM
eliXion
Dec 4, 2006 08:48 PM
jhawk1977
May 2, 2006 05:35 PM
