2.8L to TDI
Old Jan 26, 2011 | 12:42 AM
pbbg's Avatar
Default 2.8L to TDI
Well last week I found out my car skipped timing from the idler pulley failing. The valves are bent and the dealership estimates around 3k to fix and I have no time right now to fix the car since I am graduating in May.
I don't have a job yet so I don't want to go out and buy a new car and have a payment that I can't afford if I can't get a job. I thought about an engine swap thinking it maybe a little cheaper than fixing the engine.
I checked out some threads and found out that a TDI engine will mount right up to my tranny but didn't find out to much on the engine mounts.
Will I have to fab up some new engine mounts for this new motor? I know I need a new ECU and wiring harness but will I need to replace anything else?
I know a few guys where debatin about doing it and if you peak in here can you post up the work if you did do it?
Thanks!
Old Jan 26, 2011 | 01:41 AM
shaferbm's Avatar
Are you thinking a TDI motor from a Jetta or something?
Old Jan 26, 2011 | 11:45 AM
pbbg's Avatar
yeah y not
Old Jan 27, 2011 | 11:14 AM
shaferbm's Avatar
I have no idea on how the swap would go, but it sounds awesome. Although from what I've seen the tdi jetta motors are more expensive compared to getting a 1.8t motor. But don't quote me on that.
Old Mar 8, 2011 | 10:00 AM
jlaudio_quattro's Avatar
BUMP
I like this idea! I love diesels! If you could get a diesel B5 here I would buy one right now!
Old Mar 8, 2011 | 04:00 PM
tware4021's Avatar
there was a guy up in Canada who did a swap. i dont know any more than that about it. lol but you could search around
Old Mar 8, 2011 | 05:20 PM
I did find one after some searching but not enough info to justify the swap yet. I need to find out what I need to do for motor mounts. One of them will work if you buy a mount for a different engine but the other you have to make yourself. I can do the rest because it will just bolt right up to my trans. This is a project for next summer. I need to do research first. Buy everything I need then FINALLY do the swap. I may not but if it can be done for a few grand not including the price of the engine I would like to do it.
Old Mar 8, 2011 | 10:43 PM
twoeightquattro's Avatar
i want do do the same thing, but with jettas and what not being FWD are the engines longitudinal? or horizontal? if they were longitudinal they would work with a quattro tranny, correct?
Old Mar 8, 2011 | 10:52 PM
erasmmuss's Avatar
U can allways import a b5 diesel engine from europe jettas engines won't work
Old Mar 8, 2011 | 10:57 PM
