2871r ??
Old Apr 29, 2009 | 11:45 PM
rallyaudi28's Avatar
Default 2871r ??
why does the oil intake fitting have such a small inlet? Can I just put a wider inlet or will it be to much flow??
Old Apr 29, 2009 | 11:58 PM
ghost6303's Avatar
its called an oil restrictor for a reason. the GT ball bearing turbos only need about 30 psi or so of oil pressure, our engines put out close to 100psi in the upper RPM range. if you remove it you will blow clouds of smoke out your tailpipe.
Old Apr 30, 2009 | 12:26 AM
A4speed's Avatar
yep, you dont want to do that...
Old Apr 30, 2009 | 12:32 AM
Thanks
aeroman28
Aug 23, 2008 07:11 PM
aRIf
Apr 19, 2006 04:55 AM
aRIf
Mar 17, 2006 05:21 AM
aRIf
Mar 16, 2006 12:34 PM
germanspeed
Mar 9, 2006 01:23 AM
