'96 cabriolet automatic transmission problem
Old Nov 13, 2014 | 09:09 PM
caffel's Avatar
Default '96 cabriolet automatic transmission problem
Mine seems stuck in neutral although will occasionally move in reverse. (160k miles)
How do I figure out which model of Audi trans I have ?
VIN WAUAA88GOTA003431
Thanks,
Charlie Affel
Old Nov 20, 2014 | 10:07 PM
Mark C's Avatar
Open the trunk and pull out the spare tire from the well under the removable panel and look at the tag glued to the side of the well where the tire is. About in the middle of the tag there will be a line that says engine code/trans code and there will be a series of letters there, like AFC CJP, or some other codes. The First is the engine code (AFC) the second is the trans code. My 96 Quattro says CJP which is a 4:11 geared awd ZF transmission, yours being a 2WD will probably have a different series of letters.
Check your transmission fluid, which is a real pain in the butt to do, but its the cheapest fix, if its low the transmission will either slip like mad, or not engage 1st or reverse unless you really rev the engine up.
AMANDA25
May 15, 2015 05:45 AM
Omega78
Feb 24, 2012 03:26 PM
shadow5559
Jun 3, 2009 02:51 AM
ANNDRE3000
Sep 20, 2008 06:13 AM
elgatogeorgi
Dec 26, 2005 01:55 AM
