97 A4 Quattro Auto, no reverse or high gear, help
Old Nov 16, 2009 | 10:33 PM
Fromert's Avatar
Default 97 A4 Quattro Auto, no reverse or high gear, help
97 a4 1.8T quattro automatic. It wont shift into reverse or high gear, all of the indicator lights on the dash are lit up. It only has 85k on it and its in great shape other then the trans problems. Any advice would be greatly appreciated, thanks.
Old Nov 16, 2009 | 10:42 PM
ghost6303's Avatar
that means your transmission is in limp mode due to some major problem that should not be ignored or else damage will be done. the car can limit use of the higher gears to protect itself, but reverse gear shouldnt be limited. have you ever had the transmission fluid changed? do you have any noticeable leaks?
the first step is getting the codes scanned. many OBD2 scanners can read the trans module in our cars but not all. VAGCOM or a dealer scanner is best if you have access to it.
Old Nov 17, 2009 | 01:11 AM
Midniteoyl's Avatar
Get the codes.. but prolly the Tranny Range Switch
Old Nov 17, 2009 | 02:53 AM
kriptonik's Avatar
Yeah, get the codes scanned and post them here.
Best of luck!
Old Nov 17, 2009 | 11:04 AM
fastturbo4's Avatar
Same EXACT thing here, too. 97 1.8T Quattro Auto w/110k. Started out with NO REVERSE with only the "N" and "D" indicators lighting up on the dash. Started AFTER I hosed%2
Old Nov 18, 2009 | 03:43 AM
fastturbo4's Avatar
bump bump bump
Old Nov 18, 2009 | 05:59 PM
ghost6303's Avatar
no ****** way im reading all that without any formating. try breaking long sentences into paragraphs.
i did see you say "I keep seeing "check the codes"!! I would LOVE to check em....except one thing....WhereTheFrick is the ALDL PLUG!?!?"
the OBD port is under the steering wheel on the knee bolster. every once in a while theres a weird car with the OBD port on the back of the center console in front of the center seat in the rear, for whatever reason.
Old Nov 19, 2009 | 01:22 AM
fastturbo4's Avatar
There...hows that for paragraphs?? Thanks for the ALDL plug info at least. I'll get it checked. Please read my thread some more then and see if you can get rid of this brain fart that I have. Thanks Ghost
Old Nov 22, 2009 | 11:37 AM
Fromert's Avatar
Default Codes
working on getting the codes. Finally found someone with a VAG that is willing to help me out. I'll post them after turkey day . Thanks again for everyone's help.
Old Nov 29, 2009 | 05:52 PM
Fromert's Avatar
Default Codes!
These are all the codes that were saved. Once they were cleared the car started to shift into reverse and high gear. I understand that a few of the codes are probably "bad ground" related. I have checked and cleaned up the main chassis ground that is on the bottom of the motor, as well as the three under the coolant reservoir. Im not sure where the others are. I also took the two plugs that are attached to the trans, and cleaned them very well. If you have any suggestions as to what else can be looked at or replaced let me know.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 907 557 N
Component and/or Version: 1.8L R4/5VT MOTR AT D05
Software Coding: 06251
Work Shop Code: WSC 06435
2 Faults Found:
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Control Module Part Number: 8D0 927 156 T
Component and/or Version: AG5 01V 1.8lR4T US D06
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
00293 - Multi-function Switch (F125)
27-10 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 N
Component: 1.8L R4/5VT MOTR AT D05
Coding: 06251
Shop #: WSC 06435
No fault code found.
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 T
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 036
Component: B5_KOMBIINSTRUMENT D10
Coding: 00242
Shop #: WSC 06435
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
janaxjoe
Sep 3, 2013 11:57 PM
murri
Oct 1, 2012 12:06 PM
PacificA4
Jun 23, 2012 09:53 PM
paulrob2808
Aug 26, 2007 09:41 AM
sukhix
Nov 3, 2005 07:57 PM
