98 A4 Quattro ignition module
Old Mar 23, 2015 | 07:22 AM
cathie98's Avatar
Default 98 A4 Quattro ignition module
Just joined the site although you guys have helped me out already lots of times as a guest. My A4 has burnt through 3 ignition modules. The first time it happened I had been running with the fog lights on constantly as my dims suck and that helped. I read on a forum that that can cause the ignition module to burn out. We replaced it, it worked until I used the fog lights again 2 weeks ago for about 20 miles. Got a warranty replacement part for free from Autozone, now it won't start again. I think it is possible that my dog could have turned the lights on while I was in a store the other night, flashers were blinking when I came out. Any one have any suggestions for a permanent fix? I am not opposed to just disconnecting the fog lights or pulling out the bulbs, although I do like them.
Old Mar 23, 2015 | 01:23 PM
MetalMan's Avatar
There's another alternative... delete the ICM and convert to new-style 2.0T coil packs. It can be a little expensive and/or time consuming, but in the end is worth it. No more ICM!
Old Mar 23, 2015 | 07:23 PM
cathie98's Avatar
I think I have misspoken. The guy at Autozone today said that it is called ignition switch-the electronic part, not the key part.
Old Mar 24, 2015 | 11:18 AM
MetalMan's Avatar
Ah that makes more sense, I was wondering what impact lights could have on the vehicle's ignition system.
Yes ignition switch is the correct term.
Audi B5 A4 Quattro 1.8T Interior Electronic Switches Ignition - ECS Tuning
Try a Genuine Audi one, many aftermarket units are known to be crappy.
Old Mar 24, 2015 | 05:11 PM
cathie98's Avatar
Okay, we put a new one in yesterday, and this morning it is already screwed up. It started, but the lights don't work. Brights will come on if you hold the arm in, like if you are flashing them. This is what it did the first time that part went bad, back in November. I think Autozone is not going to want to give me a new one on that lifetime warranty plan every time I drive my car. Something has to be shorting out, but how to find it?
Heber
Jan 19, 2010 05:01 PM
gironhe
May 8, 2009 03:18 PM
kiellish
Mar 4, 2009 02:35 PM
georger
Nov 17, 2008 06:08 PM
Belligerenceā„¢
Jun 24, 2008 10:16 PM
