98 audi a4 1.8t low compression
All of this things can be the reason for low compression on a piston or all the pistons.
your engine would be running pretty rough with that low of compression on a cylinder. try retesting multiple times. if you have only a couple misfires it probably indicates something else
It said misfire on cylinder 2 so i test that one and cylinder 3. cylinder 3 was good but cylinder 2 was at about 60. I checked the spark plug and it was burning good and i checked to see if it was a bad coil pack and it wasnt.
and as mention before only way to find out is take the dam thing apart lol
Low comprssion will cause misfire and there is no way to really take care of it without at least dismantling the top end. It could be due to bad rings, but when only one cylinder is involved it usually a bad head, bad gasked, or a valve train problem. All of which requre dismantling the engine to some extent.
18t, 2000, 98, a4, audi, b5, car, compresion, compression, kompression, loss, low, springs, start, stock
