99 2.8 Will not idle sounds bad, checked vacuum
Old Aug 20, 2009 | 09:52 PM
theother1wstolen's Avatar
Default 99 2.8 Will not idle sounds bad, checked vacuum
As the title says I'm working on my friends 2.8 and it was throwing a p0411 so I checked/replaced all the vacuum lines cleared the code and it hasn't come back. The engine sounds almost like something is loose in the head or something, but not quite. It does run with your foot on the gas but the more you rev it the louder the rattling/knocking sound gets. I did adapt the throttle body. At this point I am at a loss, the display is showing the oil icon, is that just because it needs to be reset somehow when it is changed? It has enough oil in it. I am completely at a loss at this point. Is it at all possible the timing belt skipped a tooth or something and is now causing it to not idle? Any ideas would be greatly appreciated.
Old Aug 20, 2009 | 11:53 PM
ghost6303's Avatar
you mean the "oh-****-theres-no-oil-pressure-so-stop-trying-to-run-the-engine" light?
Old Aug 21, 2009 | 07:26 AM
ImTheDevil's Avatar
I'm wondering if a cam chain tensioners failed. It would certainly destroy the idle quality and make a hell of a racket...
02A4kid
Apr 10, 2014 04:49 AM
AuDiCaInE
Nov 13, 2013 10:27 PM
Tizhuan
Nov 6, 2010 05:54 PM
A4 2000
May 28, 2010 02:32 AM
Mercaddict
Sep 14, 2009 03:52 PM
