99 a4 secondary air injector
Old Jan 31, 2015 | 10:30 PM
bmoore98A4's Avatar
Default 99 a4 secondary air injector
mine whistles really badly on cold starts. is there a way i can remove it completely? supposing so, can i code the computer to forget about it so no CEL? is there a cheap way to repair mine if the above prove to be troublesome? lol
Old Feb 1, 2015 | 08:04 PM
Mad Cow's Avatar
Sometimes you can fix the pump by replacing the rivets that hold the 2 halves of the casing together with long bolts.
Old Feb 1, 2015 | 08:26 PM
normal's Avatar
There is a guy with a video in youtube that gives a how to on this. Can't recall exact title but you'll ons it I'm sure. He had been quotes > $1k by dealer and fixed for (I think) ~ $100 or maybe less
Old Feb 2, 2015 | 05:50 PM
Mad Cow's Avatar
$100? It's literally $5 worth of bolts and nuts. Mind you it'll only work if your pump is fine internally but leaking air through the casing.
Old Feb 2, 2015 | 06:14 PM
normal's Avatar
I was simply trying to share a possible source of more info that went into a fair amount of detail on the topic.
Old Feb 4, 2015 | 03:28 PM
bmoore98A4's Avatar
thank you, both of you. I am about to be going into service position 1 and was curious about the removal of it. But repair is fine too! suppose the pump is shot, can i remove it still?
Old Feb 4, 2015 | 07:19 PM
Mad Cow's Avatar
You could but you'll have a CEL unless you get a tune that removes SAI diagnosis. There's no way around it, no 'good-enough' hack. It monitors the actual airflow put out from the pump so there's no way to fool it through purely hardware means.
Old Feb 5, 2015 | 04:00 PM
bmoore98A4's Avatar
thats a pain in the butt. thanks for the info.
A4TurboGuy
May 11, 2014 11:20 AM
tpkg
Mar 27, 2014 03:23 PM
ungawa
Aug 9, 2010 10:16 PM
JSSAA
Apr 27, 2008 03:15 PM
flyboy
Jan 1, 2006 04:12 AM
