99 A4 will not run! Only throwing O2 code!
Old Mar 12, 2013 | 06:11 PM
Mad Cow's Avatar
Of course you need the engine running, you need to read the live sensor data, not trouble codes. Go through the measuring blocks and see what kind of data you have available before starting it so that you'll actually have time to see what's going on before it shuts off.
Old Mar 13, 2013 | 06:38 PM
Davidf269's Avatar
Now the car will not run at all although it did try a little indicating that I have spark. I should have mentioned the following in my original post. When I went to rescue my car ( and my sister!) the first thing I did was take the gas cap off, there was no release of pressure like you would normally get? Maybe my fuel pump has given it up? How do I check the fuel pump ?? If this were an old Carbureted car I would know just what t do...
Old Mar 13, 2013 | 06:52 PM
Davidf269's Avatar
Ok I will push the car back over to the side of the house and hook her up, crank it over and see what happens. I think my fuel pump has either failed or is not being told that its services are required... Thanks for your Patience...
Old Mar 14, 2013 | 04:57 PM
Davidf269's Avatar
Fuel pump fuse is ok , (#28 fuse) ran 12 volts directly to pump with nothing happening. Guess I need a new pump?
Bryanfav123
May 10, 2014 02:18 PM
less_of_me
Oct 28, 2010 07:03 PM
Theferk43
Jun 4, 2009 10:33 AM
pete7
Nov 13, 2007 09:05 AM
Anos
Mar 26, 2007 01:59 AM
