Old Feb 14, 2011 | 08:19 PM
euroimport88's Avatar
Default ???
how many gallons are in my tank. it shuts the pump off right before it hits 12 gallons. do i need a new float or what. 96 2.8 12v
Old Feb 14, 2011 | 09:54 PM
Sohcvtec1995's Avatar
run it dry, put half a gallon in a gas container, drive to gas station, fill up. i would say around a 15 gal tank
Old Feb 14, 2011 | 11:46 PM
twoeightquattro's Avatar
no, don't run it dry. i usually put about 13.4 gallons in, this is when the gas light is on.
if you run it dry, it could suck up all the sediment from the bottom of the tank, and can clog fuel lines, filter, etc.
my gas guage sometimes reads falsely as well
Old Feb 15, 2011 | 06:03 AM
ImTheDevil's Avatar
It's a 16 gallon tank. Light is designed to come on with 2 gallons remaining. If your gauge is screwy, search "fuel sending unit" to find the reconditioning DIY, and While you have it out, use electrical contact cleaner to clean the resistive element. That should take care of any inaccuracies.
Old Feb 15, 2011 | 08:29 PM
i did clean the contacts points and did the diy but got nothing
Old Feb 15, 2011 | 10:43 PM
erasmmuss's Avatar
U have to replace that wire check my diy on the subject i fixed mine las weekend and it works perfect with perfect reading and when u clean the contacts u might have bent the reading head is common
