where is this oil coming from??!!
It is normal.
Though the PCV valve that sits in your inlet tube may be getting gunked up, I suggest you change that, along with any other broken pieces of PCV. These cars use a blow by system, there will always be oil in the intake tract. From your photos you have a relatively normal amount of oil in there.
If your CHRA was going bad you'd have significantly higher amounts of oil than that.
Well, millions of years ago, some **** died, got trapped in some ****, turning into some sort of ****. Millions of years later, some dudes dug the **** up with some digging ****, processed the **** with some ****, and put the **** in a plastic bottle. Then, you bought the **** and added it to your engine, where some shitty seal took a **** and leaked the **** inside the engine to where it it now...
Ain't that some ****?
